Use Cases
UCaaS
— UCaaS
Unified communications, built your way
SignalWire gives you programmable unified communications: voice, video, messaging, and AI on one platform, so your UCaaS is something you program, not a rigid prebuilt suite.
SW-UseCase-UCaaS
The hard part
One platform for every communication channel
Voice, video, messaging, and AI, addressable, programmable, and unified under one system instead of five vendors.
Traditional UCaaS locks you into a fixed feature set and someone else's roadmap. On SignalWire, every phone number, SIP endpoint, video room, and AI agent has its own address you can reach and program directly. So your UCaaS does what your business needs, not what the vendor shipped.
How it works
One system, everything programmable by address
On SignalWire, every phone number, SIP endpoint, video room, subscriber, and AI agent has its own address you can reach and program directly. Connect them with declarative call control and REST or real-time APIs to build the voice, video, and messaging flows you need, then scale from 10 users to 10,000 without re-architecting.
01
Model your users as subscribers
Every user, agent, and device is a subscriber: a durable identity on the platform with its own addresses, presence, and multi-device reach. This is the piece a prebuilt UCaaS suite hides from you.
02
Make everything addressable
Subscribers, phone numbers, SIP endpoints, video rooms, and AI agents are all addressable resources. Reach any of them by address.
03
Program the routing
Declarative call control (SWML) plus REST and real-time APIs connect those resources into the voice, video, and messaging flows your business actually runs.
04
Add AI as a native participant
Voice AI agents are addressable resources, so an agent can take a call, hold a queue, or hand off to a human on the same platform, with context intact.
05
Scale without re-architecting
The same call flow that handles 10 subscribers handles 10,000, with no servers to provision.
01
02
03
Program the routing
04
05
01
02
03
Program the routing
04
05
Build it
Stand up a programmable SIP endpoint in minutes
Dial two SIP endpoints in sequence with a timeout and fallback, all in a few lines of declarative markup.
Dial SIP serially with a timeout
copy
01
02
03
04
05
06
07
08
09
version: 1.0.0
sections:
  main:
    - connect:
        timeout: 20
        serial:
            to: "sip:alice@example.com"
          - to: "sip:bob@example.com"
            codecs: PCMU
copy
01
02
03
04
05
06
07
08
09
version: 1.0.0
sections:
  main:
    - connect:
        timeout: 20
        serial:
            codecs: PCMU
copy
01
02
03
04
05
06
07
08
09
version: 1.0.0
sections:
  main:
    - connect:
        timeout: 20
        serial:
            codecs: PCMU
copy
01
02
03
04
05
06
07
08
09
version: 1.0.0
sections:
  main:
    - connect:
        timeout: 20
        serial:
            codecs: PCMU
What you’ll learn after the quick start
Route any call to any destination, a person, a phone number, a video room, an AI agent, from a few lines of code.
Control how calls behave, ring time, caller ID, fallback order, all set in the flow, not in a vendor dashboard.
Reach people how they're actually available, ring several endpoints at once or in sequence, so calls land instead of bouncing.
Know what's happening on every call, get told the moment a call connects, fails, or ends, and act on it.
The platform behind it
The SignalWire products behind Unified Communications as a Service (UCaaS)
Four building blocks combine into a full UCaaS stack: voice, video, messaging, and the addressable resources that tie them together.
Voice
Place and receive calls over PSTN, SIP, or WebRTC, with call routing, conferencing, and IVR built on the same API.
Video
Spin up video rooms for meetings and collaboration, addressable the same way as a phone number or SIP endpoint.
Messaging (SMS & MMS)
Send and receive SMS and MMS from the same platform handling voice and video, no separate messaging vendor required.
Build voice agents in Python, or other languages, that answer questions, act mid-call, and hand off to a human with the conversation intact, on the same platform as your voice and messaging.
Subscribers
Give every employee an addressable identity with their own extension, credentials, and routing rules, no separate user system to build.
SWML
Define call routing, IVRs, and transfers as YAML or JSON, the logic layer that ties every resource into one call flow.
Voice
Video
Subscribers
SWML
Voice
Video
Subscribers
SWML
The hard parts
The hard parts and how SignalWire handles them.
The Challenge
How SignalWire Handles it
A prebuilt UCaaS suite gives you a fixed feature set tied to the vendor's roadmap.
SignalWire exposes every part, voice, video, messaging, SIP, as a programmable building block you control directly.
Voice, video, and messaging usually come from separate vendors with separate bills and separate outages.
One platform and one API handle all channels, so there is one system to monitor and one bill to reconcile.
Legacy on-prem PBX and end-of-life platforms leave teams without a supported migration path.
SignalWire provides a cloud-native, programmable replacement for legacy SBC and Class 5 switching, with an active support team behind it.
Adding AI to a UCaaS deployment usually means a separate vendor and webhooks to wire together.
Voice AI agents run inside the same platform as your calls and messages, with no extra network hops adding latency.
The Challenge
In production
Built by teams that unify communications at scale.
  • "Just having basic programming skills, SignalWire kind of takes over all the heavy lifting on the telephone side and makes my life so much easier."
    Avatar
    David Plappert
    Founder at PhoneLiveStreaming
    Avatar
    David Plappert
Read how a solo founder shipped a live-audio product in six hours and scaled it to 2.5 million minutes a month.
    Avatar
    David Plappert
    Avatar
    David Plappert
    Avatar
    David Plappert
    Avatar
    David Plappert
FAQ
What to know before building your own UCaaS product, from compliance to CRM integration.
What is Unified Communications as a Service (UCaaS)?
UCaaS is a cloud-based model that delivers voice, video, messaging, and collaboration tools from a single provider, so businesses do not need to manage on-premise PBX hardware.
Can I use SignalWire to build my own UCaaS product?
Yes. Software companies, carriers, and managed service providers use SignalWire's APIs to build and resell their own UCaaS offering under their own brand.
Is UCaaS built on SignalWire secure and compliant enough for regulated industries?
Yes. SignalWire is SOC 2 Type II certified and aligns with GDPR, CCPA, and PCI. TLS and SRTP encryption are on by default at no extra cost. For healthcare, HIPAA-compliant infrastructure with signed BAAs covers voice, messaging, fax, video, and AI workflows under one agreement.
Can I port our existing business phone numbers over to a SignalWire-based UCaaS setup?
Yes, existing local, toll-free, and short code numbers can be ported in, so switching platforms doesn't mean reissuing numbers to every employee or customer. Porting timelines follow standard carrier processes, typically longer for toll-free and short codes than local numbers.
Does a UCaaS build on SignalWire integrate with the CRM or helpdesk tools we already use?
Yes. The SignalWire platform can sync call data, automate lead routing, and trigger workflows in tools like Salesforce, HubSpot, and Zendesk, so call and message activity shows up where your team already works instead of living in a separate UCaaS dashboard.
Ready to ship your UCaaS offering?
Start building a UCaaS offering on programmable voice, video, messaging, and SIP, all under one platform and one bill.
